Which Trigger do I have?
72mtwain
Need to order a trigger, wires on mine are shot. Merc 850, 1976. there is a straight arm and a hooked arm listed for this year engine. I can't tell which I have. The part # on the original crosses to the straight arm. Just wondering if anyone knew for sure before I ordered one... Thanks.
chum1
Re: Which Trigger do I have?
you can look up under the flywheel at the linkage if the trigger arm has a 90 degree bend its the "hooked arm", I am guessing thats what you have as the 76 and 77 models are pretty much the same, the triggers are spendy and will not interchange.....guaranteed!!!
