mohead1
- Jun 18, 2011
- 134
Ok, working on a new to me boat, Wellcraft 210 with 5.7 Merc, 260, Alpha 1. Put the muffs on, ran the motor for 15-20 min on the hose, checking for impellor flow. Good water coming from the ports at the gimble mount area. Good oil pressure, temp. hovering at 200-210, rpm from idle to 3500. Motor sounds good, no oil smoke. Now Im thinking too much, is the pressure from the house hose providing the flow, or am I seeing the impellor pumping. How about the high temp on the gauge? Dont want to hit the water and find out no impellor flow. Should I put the drive into a barrel of water and let it draw its own water without the hose pressure to test the impellor?
Also, going into reverse, slight chatter/ticking, then bumping the idle a little it falls into gear, maybe a cable adjustment? It is a 1988 boat, but in real nice condition. Just dont want to be looking like a stooge being stranded on the lake....
Comments from the gallery please....
