Hope some one has suggestion. When motor is running you have to start it with the button pulled out and reved up. The choke works fine. As the motor starts to idle down you have to be quick to push button in and get it in gear and start to throttle up. It runs ok up to about 1/4 throttle after that the more throttle you give it the more it falls on its face until you back it down to 1/4 throttle. Any suggestions? Please help:
