Hello There,
This is my first time on this site and hopefully someone can offer me some advice on my troubles!!
I have a 1991 4.3 merc with alpha one outdrive.I use it in salt water but flushed after every use.I notice after a day of running today in salt water,when i brought it home and ran it on the muffs, i noticed when brought up on rpms (not in gear)i could hear a rattling noise coming out from what appears to be the outdrive.It does not make the noise at idle only when i bring up the rpm,s.also the outdrive was tilted up. I have never heard this noise before, although i don,t ever recall raising the rpm,s on the muffs before. But tonight i was in a bit of a rush and wanted to flush it quickly. Also i don,t know if this as anything to do with the problem, but when i am in the water and go to reverse the engine stalls.
If someone could help with my troubles it would be greatly appreciated.
Thanks
Roy
Thanks
Roy
