Re: seat ideas
It took less than an Hour to build. All parts readily available at Lowe's
10' of 1" Schedule 40 PVC
8 90? Elbows
8 "T" 's
Cleaner and Glue
Bottom is 18" square. Top is 9" square
8 - 81/4" pieces for base
8 - 4 1/4" pieces for top
4 - 10" pieces for risers
Dry assemble first and mark pipe at all junctions of elbow fitting for angles of "T" 's for risers. Disassemble and glue base and top up and set "T" 's to the marks made on the pipe. Then glue in the risers. Cut wood piece for top. Coat with epoxy and drill holes in corners for 1/4" Stove bolts. Use Lock nuts to attach.
