1994 Mercruiser 5.0 runs fine at speed but idles a little rough & sometimes dies. Hard to restart when warm; must open throtle fully. #1 cyl only 30 psi and leakage probably past intake valve. Other cyls 135-150 psi. Will a valve adjustment help the issue or must the heads be pulled? How long a job is it to pull the heads? Will continuing to run the boat (carefully) cause further damage?
