Model number of outboard is 100ESL72R. Sierra power pack that is currently installed died on me. Instead of pulling the flywheel off to replace the whole wiring harness I'm thinking about just heat shrinking the old Sierra(18-5748) quick connect adapter onto my CDI power pack unit. All of the wires are color coded and match up exactly but two of the wires are black with a white stripe. Does it matter if I have these wires crossed? Both of these wires seem to go up under the flywheel (along with a green wire). Not exactly sure what there function is. I have already accounted for the blue (coil) and purple wires.
One other thing to mention. The green and two black striped wires have a fitted metal connector break in them pretty much right where the quick connector would have to sit. Not really seeing a way that this would help my cause out though. Any thoughts? Thanks for any help in advance!
