I've finaly figured out the spark problem and have strong spark at both cylinders now. Tested everything in my driveway before I took it to the lake, staetrted perfect and reved up just like it should. Got around to taking it to the lake a couple days ago and for the first 30 seconds everything was going great. Started fine at the dock pulled out and started to open her up half throttle( engine was purring like a kitten) then got out a little ways and it started to sputter and eventually died. Got it to start again but would only run at quarter throttle and barley move maybe 2mph max. Checked it out again in the driveway and same thing even with no load it wont rev past quarter throttle. Still starts fine and idles ok but does this thing where it has a backfire hiccup every couple seconds. Does this sound like a bad float adjustment or more of an electrical issue. I also talked to a guy at my work and he says it could be an air leak??
