115 seahorse
ralphy02
i just purchased a pontoon the motor hasnt been ran since last spring i know there is some important things need to be done before taking her out on water the motor started right up and ran when i purchased it i would figure plugs and water pump but if anything else is needed can u please help?
jbjennings
Re: 115 seahorse
You might consider new fuel lines, and for sure check your lower unit oil. Make sure your fuel is fresh and fuel tank clean. Clean fuel is vital!!
Good luck,
JBJ
