Druidsnightmare
- Jul 1, 2011
- 2
First off let me hey hello and good day to all! You have a wonderful site full of a vast amount of knowledge . I have been perusing the forums for a little while now trying to troubleshoot my Johnson HD-25 engine. I realize that there have been several posts about getting a spark to these engines and I have done all that I can think of to try and get a spark. The coils were replaced as well as the condensers and the points were fully disassembled and sanded down to bright metal and set to .20 as well as buying new spark plug wire and new boots as well . I?ve gone as far as even replacing the ground wire and any other wires that looked corroded just to try and rule out the wires as a possibility of non-spark. I followed a link from a previous post to the Poche ignition test and followed it to the letter when the points are open the ohms meter drops to closed so the points are functioning correctly. I also bought a spark tester from advance to check now I know this wasn?t smart but when I held the sparkplug wire in between my fingers and turn the flywheel I get a shock but when I plug in the tester nothing. I bought this engine off of ebay and came to me seized, freed it and now dealing with the ignition problem, the last thing I wanna do is admit defeat so I need a lil help from those who know more than me. Any help at all would be appreciated.
