Help needed,thanks in advance.
cm27rg
OK so I picked up an old suzuki DT25hp 2stroke outboard on the weekend.
It starts ok but i can't see where the tell-tale is so i can't confirm the water pump is working.
Also the exhaust outlet ,is that from thru the prop?
Any help would be appreciated,thanks in advance.
And what would you say the best fuel mix is .
thanks ,dan.
