I have an 1984 90hp which I bought recently. After using a couple of days, I was out in lake ontario anchored up and went to restart after fishing a couple of hrs. Didn't start, just click and hum. Changed batteries and same issue, then 2nd try it fired up and I headed for the dock. Parked it, restarted no problem and hauled it home.
When I tried to start at home, it wouldn't start. Pulled the cover off and noticed the starter was spinning fast but the pinion and shaft with the spring was not rising up to engage the flywheel.
Seems batts are fully charged.
Is this a bad starter? selenoid?
Things look pretty clean at the connections.
Please help.
Please help.
