chevy 3.0 mercruiser dies when throttled down to idle
altalburt
I have a chevy 3.0 mercruiser that dies when it is throttled down to an idle. High end runs just fine but when pulled down to idle it dies. I have cleaned spark arrester, changed filters, plugs, put in new gas with sea foam additive, ran the boat on the for 20 miles but the problem still occurs at odd times. Any ideas?
Shelby Ladner
Re: chevy 3.0 mercruiser dies when throttled down to idle
Mine was doing same thing but it also would not fire back up without pushing throttle all way forward. Try looking into open mouth of carb after you shut it down to see if fuel continues to drip. Might be carb rebuild time.
Rocky_Road
When it does idle, what is the rpm's?
Ayuh,... Sounds like a Carb problem,... Try rebuildin' it...
Raypex
I am certainly no expert and this may not even apply but isn't there a shift/kill or interupt switch that allows the drive to shift when the throttle is backed off?
I think there are adjustments here.
If I'm way off, i'm sorry. Just tryin' to help
Good luck.
