greg82255
- Oct 26, 2009
- 781
So I just went out and bought 4 LED cabin lights for my Formula. They all looked great on display at West Marine so I picked the ones I wanted and went home. I can post the models if necessary. I started connecting them in series (Negative wire of one light to positive of the next, and so on), and when I went to flip the switch light them up, 2 of them barely lit, and 2 didn't light at all. I thought maybe something was connected backwards, but I checked all the connections and they were correct. I then tested each light individually using the battery in the boat, and they all lit up very bright. I realized they draw different amounts of current, so connecting them in series was causing the brightness problem. However, I've read posts that say not to connect LEDs in parallel. So, my question is, what is the best way to wire these lights? Should I wire each one individually, put them all in parallel, do I need resistors, etc? Any input is appreciated.
