1977 SILVERLINE
- Jul 11, 2011
- 113
My 470 is hard starting hot with the engine cover installed. If you run the boat with the cover removed I don't have much trouble with hot starting. The engine has a closed cooling system which looks like it runs coolant through the intake to cool it I am guessing. Does this sound like a vapor lock issue? My boat has a closed bow which is where the fuel tank is located. The fuel pump is engine mounted and has to suck fuel from 20 feet away. I was thinking about installing an electric fuel pump close to the tank in the front to push fuel rather than pulling fuel.
Thanks
Thanks
