Hello everybody, I'm new to this forum and just hope to get some help. I have a 93 2stroke Evinrude 55hp. It starts up and idles and runs at low rpm very well. Once it hits probably about half max rpm is runs very rough and shakes and bucks bad and loses power. I've seen several posts about the s.l.o.w mode and this seems like exactly what the problem is but there isn't a brown wire leading to the cylinder head like they talk about. I can give full throttle and it runs great until it gets to this specific RPM, probably around 2500? It does the same if I bring it up slowly and it is very sudden, not gradual at all and I know it is a specific RPM, not throttle position. I have replaced the power pack and ignition coil so I know this brown wire doesn't exist on this model. Also replaced spark plugs and cleaned the carbs and jets. Fuel and pump is new and filter is clean. Also, pulled the choke when this symptom hits and it doesn't change anything so I really don't think its fuel. Anyway, sorry this is so long but I just want to put all the information out there. Please help
