HELP HAVE A 1986 200HP EVEINRUDE THAT WAS IN STORAGE 3 OR 4 YEARS WITH A 91 POWERHEAD . HEARS THE PROUBLEM IT SEAMS TO RUN FINE AT 900 RPM BUT WHEN YO START TO PUSH IT UP SLOWLYI ABOUT 1500 RPM TO 2500 RPM IT SLOWES DOWN AND THEN RACES UP ABOUT 200RPM UTILL YOU PLAIN OUT THE BOAT AT WOT IT RUNS GREAT BEFORE THE OUTBOARD WOULD START WHEN I FIRST LOOKED AT IT I HAD TO DRAIN ALL THE CARBS ,THEY WERE FILED WITH FOGGING OIL THAT WAS IN THE CARBS I JUST PUT IN THE WATER AND AND HAVE NOT RUN IT LONG COULD IT BE A FOWLED PLUG FUEL FILTERS PRIMER BULB THIS WEEKEND I WILL CHECK IT OUT ANEY OTHER IDEAS WILL BE GREATLY APRICATED THANKS
