Re: 28 SPL Evinrude shifts into neutral at half throttle.
As soon as you back off on the throttle, I'm assuming it goes back to normal? If that's the case, then y'up it sounds like prop slippage. There is a clutch dog in the gear case, but I'm not the one to tell you how much to repair. I'm replying so your question stays on the main page, otherwise it will get overlooked. How long has this been happening: is it a new problem or a new-to-you motor?
