strtbobber
Thread starter- Joined
- Oct 12, 2010
- 212
I've run my 35 Chrysler about 6 or 8 trips now. It has run perfect. Rebuilt carb, rebuilt fuel pump. Timing adjusted. Points were good.
I've used it only for fishing until yesterday. That's when I pulled a tube for the first time. It ran perfect again. Today I took it out tubing again and I could not achieve full throttle. If I nailed the throttle out of the hole, the motor would bog right down to nothing. :facepalm: If I creeped the throttle up slowly, I could get the tube to plane, but that's about it. If I tried to creep it all the way up to full throttle, it would bog...(and it would have died if I would have kept the throttle pinned). So, I could get MAYBE 3/4 throttle/rpm today, that's it.
I unhooked the tube and went for a ride alone and it was perfect.....ran great! I made minor mixture adjustments, and eventually ended up with the adjustment where it originally was.
The best example of what it was like pulling the tube was like when you get weeds around the prop......it'll go, but there's not much rpm or speed.
Any ideas? Thanks!!
Any ideas? Thanks!!
