Starter spins but does not engage flywheel
pontooner1996
2002 Mercury 50hp OB starter spins but doesn't engage flywheel. Replaced starter no change. Jumped two large connections on solonoid does same thing. Will check connections, any other ideas? Thanks in advanced
Barnacle_Bill
Re: Starter spins but does not engage flywheel
Probably 95% of all starter problems is electrical. Is the battery fully charged? Check all your connections. They must be very clean and tight. Check the lugs very closely for any signs of corrosion. They can corrode inside where you can't see it and cause the problem you are having. If you know how to do a voltage drop test you could check them that way. Another way would be to temporally substitute the cables with jumper cables. If all the cables have been confirmed good, try jumping the starter solenoid. Just because it clicks does NOT mean its good. If you are sure the solenoid is good have your battery load tested, regardless of age. This brings you to the starter itself. Remove it and have it tested by your local auto electric shop. They can rebuild it for you if needed and save you some money. Let us know how you make out.
Will Bark
Agreed with above also check the bolts holding the starter to the block, make sure they are clean w/no corrosion and tight.
TD_Maker
If you are using the butterfly connector bolts on the battery, really crank those babies down with a pair of pliers. Better yet, replace them with regular nuts and washers to assure a great connection.
boobie
Is the starter spinning in the right direction? Battery in backwards?
Midnight Krawler
Possible causes: Motor spinning to slow, gear is stuck, motor is spinning backwards. battery voltage to low.
One important question, is the gear on the starter motor rising up when it spins? Does it slide up easily by hand? It should.
