I have a 5.0L GXi. Engine SN: 4012061196.
Impeller went out on it a week ago. Replaced the impeller (With sierra 18-3020) and housing. Now the engine will not pull fresh water to the pump. I have back flushed all of the hoses between the boat and the lower unit. Everything flushes freely but still no prime. Any suggestions? I've double checked all of the connections and I am sure that I hooked it up properly. About the only thing that I can think of is that the O ring on the sea water pump is bad. I have double checked it and it is in tact, just not sure if its "tired."
