Hi guys, this is my first post although I've already learned quite a bit just searching the posts, so thanks for being so smart about boats and passing the knowledge on.
I've been out of boating for 20 years and just recently bought a 93 Regal with the 4.3LX/Alpha1/TBolt IV setup. It had been neglected but I've got it running really well by just doing the basic tune up stuff (dist, rotor, coil, wires, plugs, timing, fuel filter/separator, oil & filter, etc.) and running some Seafoam through to clean out the carbon.
Really the only other tuning issue I have is that it's hard to start when cold. The problem is that the choke won't close. If I manually close it, it starts right up. It's got what I guess is called the "Automatic Choke" with a rod running from the choke butterfly shaft down into a little box on the intake manifold that houses a metal coil. It doesn't seem to be electric so I guess it's activated by engine heat? Is that right?
I bought both the Seloc and Mercruiser factory manuals and amazingly, neither one has anything on this choke. They have info on the electric choke that is used on other carbs, with the black plastic housing on the side, but not on this Weber setup.
So here are my questions:
Is there a common problem with these chokes that I need to check?
The choke rod is hooked up on the butterfly rod, but I can't see down into the coil housing to see if it's come off there. Do I have to remove the carb to get it off? There's a screw holding it to the manifold but removing it does not allow the housing to come off easily. It might just be the seal to the manifold is stuck, but I didn't really want to start cranking on it until I knew the proper procedure.
I looked at a lot of Merc parts places (including iBoats), and either these choke parts are not listed, or they're shown as discontinued. Anyone know of a source if I need new parts?
Has anyone converted one of these to a manual choke? If so, where did you get your parts and what parts did you use?
Thanks for the help.
