The tilt on the motor got stuck. i had to disconnect the battery because the hydraulic motor was running. I took off the hood and traced the wires to the tilt Module. I removed the cover of the module aand exposed what looked like 2 littles black harness boxes on the left side of the motor. With the cover removed the tilt works fine, put the cover back on and it sticks in the up position. I do not see any exposed wires that could be shorting out. Is it time for a new module? Please help
