bobby bushay
- Jul 14, 2011
- 26
This is my first post. I can't even begin to tell you how much this forum has helped me out. Thank you for your time and patience in advance. I have a 95 Alpha1 3.0l/LX. When i bought the boat the owner told me it was so low on gas that the gas gauge would not show a reading. When on my first trip to the gas station it only took 6 gal of fuel i quickly figured out the gauge didn't work and it was almost full of 1-2 year old ethanol gas. So... i found iboats and used the old threads to do the following. Drain old gas, i took off fuel pump to get at bowl fuel filter and changed, filter at carb also changed, i will be installing a fuel water separater to the engine compartment. Do i pour gas back into fuel pump and new water fuel separater before i try and restart? Did i miss anything else? Worried i could burn somthing out or not get engine started if i don't put gas in to prime new stuff. Thanks.. oh i did fix fuel gauge, again, thanks to old posts. Bad ground at send unit.
