Alright, We recently were given a 1977 Johnson 70 hp. with out a lower unit. So the search began, I found another motor in another neighboring state that was supposed to be a 1977 as well. I bought the entire motor with L unit and prop. They both were a four spline. I checked the impeller and changed the lower unit fluid. It matched up great and after a little work got it o seat. I connected the shift lever and now it seems the shifter is hard to get into gear and does not seem to be shifting into gear properly. With the shifter in the upright position, the prop will not turn freely and is in gear. After reading a few post on here it seems that we either have a lower unit from another year, or the shift rod got turned. The rod comes thru the bottom of the cowling fine and when turned the correct way fits into the coupler at end of the shift lever.
The motor we have does not have any id on the manifold section, transom mount or freeze plug. The replacement motor says it is a 76 on the id tag but on the sticker on the engine it says "1977 17 degrees" but the lower unit fits fine. Just an FYI the lower unit when bolted up all 5 bolts go in fine but the tear drop or back end of the lower unit is off a little to one side by about 1/8 inch. maybe different molds?
Also how do you adjust the trim tab on the lower unit?
Incidentally the carbs on these two motors are different. One having and electric choke or injection and the other has carbs with a choke lever that is controlled by the choke spring. Did they use different choke systems and carbs on the same year?
