1985 50HP 4cyl Mercury. SN: A133192
The motor will shift into forward, but not reverse. Checked the lower unit and found black peanut butter, with some metal shavings...especially on the magnet. Replaced fluid, no improvement (didn't think there would be).
How can I know if the shifter mechanism is working? I can see the shifter cable move the lever at the base of the engine compartment, but is there a certain amount of travel I am looking for?
It worked one day, then over the next few times it required harder or further shifts until it no longer worked at all. Kinda had to throw it hard into reverse to get it to work, and then it would clunk hard.
My best guess is that the gears are tore up. But my question is how do I know if the problem is the lower unit or the shifting mechanism?
And lastly, if the problem is the lower unit..is it best to replace or rebuild. I'll be doing the work myself, and I'm new to outboards, but handle car and other repairs adequately?
Thanks for your thoughts!
