New to the forum. Thanks in advance for the help. Purchased 1971 Johnson 6hp. Was pumping no water out the exhaust port, so put in a new water pump and pumps water like crazy. But ran for a bit and then froze... way overheated. Loosened the cover off the thermostat housing and when it cooled down, ran it again and water seeped from the gasket, so is getting water to there. But there is no thermostat in that housing. Does there need to be? And any ideas why with water pumping so well it is still overheating? Hopefully didn't mess up the heads with the overheat. Thanks
