In the last year I have replaced my starter 3 times, the dealer replaced the Mercruiser brand starter with a Sierra brand. On the first two replacement starter the Bendix has rusted to the point it no longer engages in about 3 months of use. At first the service center figured it was bilge problem and replaced my bilge pump.
While I thought it might be that Sierra produced sub-par starters. But after looking at the last starter they replaced, the only rust is on the Bendix while the starter body shows no rust, not the bendix is completely seized with rust. With this mind I am thinking that either my bellows is leaking or something else is getting water on the flywheel which is getting on the starter Bendix. Note while I do get water in the bilge, we are not talking gallons but enough to get the bilge to activate during a days use maybe a up to a gallon.
Anyone else has similar problems that they can share. One thing to add is that I had the leg replaced after it failed, two year ago at which time the bellows were also replaced. The started worked for that season though somewhat noisy.
