shadowrider
- Feb 19, 2009
- 195
I just purchased a pontoon boat with a mercruiser 3.0 . There is a waterline inside the motor pod, up to the alternator. I know this is not good. I decided to investigate the bilge float switch. To my dismay, it was bypassed and totally disconnected, bilge works off switch on dash. I found float to be defective so I am going to replace it. Can it be wired so that I can manually run it and have the float switch come automatically also ?
I still have to take the boat to water and observe how much water comes in and if bilge can keep up or if I need to spend some bucks to reseal. Thanks for your thoughts.
