i just bought a 78 evinrude 70hp cleaned and rebuilt carbs replaced plugs, changed coils, rebuilt fuel pump, change hoses and primer bulb but motor wont idle below 1100 rpm or it will die in gear. and when you go to take off it will bogg and then pick up and run like the wind. im thinking of replacing the reeds but not sure any suggestions.?? oh yeah and compression is 100 on all cylinders.
