Hi everyone -
Could really use some help here. I have a 2001 Moomba with a 5.7L inboard engine. I'm new to boating and have only had this boat for about 2 months.
For the first time I hooked it up to a flush adapter to run it in my driveway to check for leaks. As I went to turn it off, it wouldn't shut down! Just continued to run with the key out of the ignition (there was no kill switch). In complete panic mood of me possibly having hooked up the flush device wrong, I disconnected the battery to kill the engine. I've since learned this may have damaged my alternator.
So...thoughts on how to fix this problem?
Could I have damaged anything else?
Before I start it up again, if it won't turn off, what would be the proper way to shut it down without causing any damage?
Thanks everyone...
Thanks everyone...
