I have a '96 EDIT 50 hp Force outboard. I recently replaced the solenoid and that fixed the problem I was having of the starter not engaging and often just clicking. Used the boat several times and everything was perfect. The boat sat for about a month, so before I took it out I tried to start it at home before heading to the lake. The starter engages, but turns VERY slowly. Battery voltage is good. Tried again and it did the same thing. I pulled the rope out and it was difficult to pull. I removed the plugs and it pulled over easily. Re installed the plugs, hit the key and it turned over normally for about 2 seconds, then slowed again. When i tried the key again the starter turned the motor slowly, and intermittently (like a car with a very weak battery). The starter stayed engaged and continued to try to crank even after I turned off and removed the key. I am very puzzled. Sorry for the long post, but I was trying to include pertinent info. Thanks in advance for your help.
