whitefeathersnpr
- Jul 6, 2011
- 1
Newbee here. I have tried searching the forum, and I am sure the answer is here, but i am just no good with the search function. I have not really worked on boats a lot but i am somewhat mechanically inclined and have worked quite a bit on cars. I would take it to a mechanic to work on but I just lost my job this week, so no money for that, hoping this is something i can fix myself.
I have recently been given a 1968 Starcraft 20' fiberglass boat. It has a 160 hp mercruiser engine with a mercruiser lower unit on it. I do not know a whole lot about boats in general or this boat in specific. The issue I have is the boat is stuck in drive. It will no shift into reverse or neutral. It runs like crazy in drive but it is a real pain to get on or off the dock with it. I am looking for suggestions on what the problem might be and how to fix it. The shift cable does not seem to be broken (as I have played with that a little tonight). When was on the water and did not push in the button so I was only activating the throttle the engine would stall out. Since the outdrive is stuck in gear, I can activate just the throttle and the boat runs great, there is just no neutral or reverse. I also need to replace the floor in this boat, but that is the subject for another post.
Thanks for the help.
J.
J.
