Sorry for the long post.
I have been trying to figure out why my boat steers way more to the left than right. The outdrive is off, bell housing off, engine out. I disconnected the steering lever andfound the gimbal ring would turn more to the left than to the right. Even so, the steering lever was still an inch from hitting the edge of the inner transom plate opening.
Moving the lever the other way, the lever hit up againstan obstruction of some transom wood that had not been cleared all the way out out the opening. (I presume when the boat was assembled.) I used a dremel and cleaned up this remaining wood and the steering lever moved all the way to the end of its travel until it bumped up against the inner transom plate opening.
So, I thought the steering would be better because the lever would now move more in the right turn direction with greater travel. Then when I hooked up the link rod to the steering lever, the rod would still not allow the lever to go its full travel turning right.
Question: the connection from the booster cylinder to the tube extension was in the hole nearest the center of the boat. There is a 2nd hole. When I hook the linkage to the second hole, the steering lever goes to the full extent of travel on right turn, and left still seems fine. Is there a problem using this 2nd hole to try and better this steering issue?
I seem to remember reading "on V8 engines use the inner hole" I cant find this reference.
Greatly appreciate any insight from someone that has dealt with this problem before.
Ed
Ed
