Who likes riddles?
I recently purchased a 18' Winner Bass boat. I purchased it thinking it has 150 hp black max XR2 (that's whats on the engine cover/cowl). I noticed the head leaking a bit of water, so Im on the hunt for a new head gasket. After 1000 calls and searching, (as well as a members input here), I think I have a 175 with a different cowl. what do you think?
Serial number A931060
Head gasket on it is 27-41247
Bore is 3.38
its got 6 cylinders
Is there any way to verify my engine size outside of the serial number? I hear its not uncommon for someone to switch out cowls in order to have more power than boat should have. Also in fishing tournaments I guess there is a max engine size? this might be a reason is was swapped?
Bore is 3.38
its got 6 cylinders
