25 hp Evinrude won't start HELP
skooter525
Model # E25ELECE, has been sitting for 2 years, checked spark ok, gets gas, pops and bangs when trying to start, thought was a timing issue, replaced the key still same thing. What else can make it do this? Please help
SparkieBoat
Re: 25 hp Evinrude won't start HELP
follow link in my sig for free guide..also follow instructions in sig
JB
Are the wires on the right plug?
kfa4303
Banned
Good point JB. The top/upper plug should have the wire with the little metal clip on it. Maybe they got switched. May need to rebuild the carb too if its been sitting for 2 years. Spitting and coughing may be due to "lean sneeze", in which the motor is starved or fuel (possible due to a clogged or dirty carb). These links should help a bit. Keep us posted.
http://forums.iboats.com/showthread.php?t=167352
http://forums.iboats.com/showthread.php?t=158086
skooter525
Also, the wires from the powerpack to the coils could easily be crisscrossed.
I will check that as soon as I get home from work thanks again. I am also going to check for a blown head gasket between the cylinders. my coils are reading 130 ohms i'm going to try a different meter and recheck, they should be at 240
skooter525
Gave up on the 25, got a deal on a RUNNING 40hp Evinrude :D
AlTn
well..that's one solution..
