1998 searay 5.0 merc I/O
p. abraham
The bilge pump switch does not activate pump, is there a fuse and where can it be found, thanks for any help,baling is back breaking.
Don S
Re: 1998 searay 5.0 merc I/O
Oops thought it said trim pump :redface: :redface:
JWebber
Don I think he is asking about bilge pump, unless he is confused on the trim vs. bilge pump. LOl!
Don S
Yeah, I read trim pump instead of bilge pump. Obviously he meant bilge pump, you don't have to bale when the trim pump doesn't work.
Moving thead to Electrical forum.
NYBo
Welcome to iboats!:cool:
There should be a fuse or circuit breaker panel under the instrument panel.
I thought you baled when you're getting the hay ready for the barn!:p
