Ok first just want to say thanks for looking and any help is appreciated. I have been have some fuel issues and have finally solved them no leaks and the motor appears to be running fine but even at idle on muffs smells of raw fuel and can see the residue in the water of unburnt fuel so decided to check fire and I have good spark on 2 & 3 and a little weaker fire on 1. Can anyone suggest how to test this properly because the way I did it was to pull the wire stick a new plug on it prop it on the head bolt and crank it to see what it looks like is this wrong?
