I have a '85 bayliner capri with a volvo aq125a /270 penta.
Sometimes when at idle and I hit the throttle, the motor will sputter and not rev up, and often even die completely.
I can usually manage to either feather the throttle or just punch it and go to get the rpms up. Over 2000 rpms there is no problem at all with sputtering and I can punch it and let off repeatedly without issue.
The problem has existed since I bought the boat, but I have since rebuilt the carb. The accelerator pump is working and all the orifices are nice and clean. I did not adjust the float, nor check its position even, as the sierra kit included no paperwork or specs for setting anything.
I've also checked the centrifical advance plates to make sure they were not rusted up or siezed in any way. I have good gas and a water separator.
Any ideas on what could cause this? I didn't think the float could do it but maybe its allowing the carb to flood?
