I received my oem water pump kit for my 1969 85hp evinrude. I have read some posts saying to use a sealant on the seal and some dont. I only have the seloc manual and it mentions to uses a "suitable sealant" any particular brands?
the sticky on the topic ( http://forums.iboats.com/showthread.php?t=309188 )uses a sealant, can i use auto sealant or is there a special variety for this application?
or is just using the rubber seal sufficient?
also you are suppose to put a little grease in the impeller housing, i realize this will get washed out so does anything work? or are there suggestions for a type of grease to use.
so to sum it up any recommended sealants for the water housing to water pump plate?
thanks
thanks
