Re: 1962 5.5 Seahorse Johnson Stripped Gears?
DISSCONECT the plug wires, and try moving the prop and shifter handle and the same time, be firm with the prop, move it both directions firmly and try slight pressure on the shifter. i do repeat tho....pull the plug wires! you dont want your motor to start while you have your hands around the prop!!!!!!!!!!!!!!
