Only1chaos
- Jul 13, 2011
- 3
Hi im new to boats and already having problems and need some help. my motor 70 hp johnson would sputters and stalls every time in neutral but if i tilt the motor up it would run fine but if i put the motor back down it will die. but in high speed it will run perfect. another thing my motor would start on the hose but when i take it to the lake it wont start unless i tilt the motor up to where the water touches the lower unit where the rabbit ear goes. once it starts i will have to put it in gear and slowly put the motor down and then it will run fine but if i put it back to neutral it will die again. any help is appreciated thanks
