Help
arky1
I have a 20HP Johnson Seahorse that was given to me. It has not been used in a couple of years, but I did get it started and it appears to be a good motor, except.... When in full throttle it runs at about 1/2 throttle, then suddenly it takes off for approx. 15-30 seconds then slows down again.
Any help would be appreciated.
Debbie
nwcove
Re: Help
depending on your budget, the first thing ...cheapest thing to try would be to try running some seafoam through it, it may/may not clean the carb up. new plugs next, then carb kit. if you see no improvement get a $10 spark tester and see if it will jump a spark 3/8 inch. if it wont , go through the compltete process in the top secret files. good luck, and dont give up!
lindy46
Re: Help
Sounds like a coil is cutting in and out. That can happen with older coils when they warm up.
kenmyfam
Re: Help
Back to the basic health check.
Compression
Spark
Fuel delivery
Spark plug condition
Post results and go from there.
Also, what JB said
