foxracing1324
- Jul 12, 2011
- 5
I recently purchased a used 1980 johnson javelin 100hp motor to repower my 19' mirrocraft. I got it off of craigslist after checking with the marina that inspected and it gave it the ok. I was told the motor had been in storage and only has six hours of use on it. After installing and testing it on my boat I found it would not accelerate over 2000rpm under load in the lake (on the hose it revs up fine). I did a compression test and got about 115 on all four cylinders and also had spark on all cylinders. I put it back in the lake and experimented with moving the throttle linkage by hand as well as advancing the timing by hand and got the motor to jump up to 3000 rpm and show signs of better performance. However, I broke the small plastic clip that holds the timing linkage on the arm coming out from under the flywheel. At that point I brought the boat to the local marina for them to inspect. I got the boat back after a month and there's absolutely no difference so I brought it back to them. They plan to test more but seem to of come to the conclusion that it has a bad set of piston rings which are keeping it from forming a strong vacuum and sucking fuel into the cylinders. due to my experience with advancing the timing by hand and getting better performance that way I feel as if its an electrical issue and would really appreciate any advice or a second opinion before I start rebuilding a motor which supposedly only has six hours of use on it. Thanks
