IRecently rebuilt the 5.7 in my 1996 Celebrity 190 with alpha 1 gen II 1.62 outdrive.
After engine was installed and aligned, the outdrive was installed. It got a new bellows kit, lower shift cable, gimbal bearing, u-joints, and the roller bearings on the input shaft.
After a few issues I got the engine running good. (originally had the t-stat installed in the wrong order with a plastic spacer which caused an overheat and a replacement head due to a crack.)
Anyways I had the boat out running good for three trips, but wanted to experiment with props. Had a 17P and installed a 21. From the start it didn't like it, but the engine was running fine just wouldn't get up in RPM.
Well at this point I developed a small oil leak that I chased back to the rear seal on the intake. Pulled down the intake, cleaned and remade the joint with some black permetex. I installed the distributor and set base time to 10BTDC while on the muffs.
She sounded good below 1000RPM but at 1200 I get a loud sound coming from the outdrive. It sounds like a fast ratcheting sound. It sounds this way in neutral and in fwd/rev.
Also with engine off and in gear either fwd/rev if you spin the prop by hand it will lock one way but the way it rotates it will have a ratcheting sound. (You can look at the shift lever and see it moving as it ratchets.)
I read this post: http://forums.iboats.com/showthread.php?t=492872 and they mention having the lower a spline off?? What does this mean and could this be my issue? When installing I placed the shift lever straight forward and slid the lower in. didn't figure that anything else had to be timed and slightly rotated the prop until everything slid home.
I guess my questions are :
(1) engine not running in gear should there be a ratchet sound when rotating the prop one way but it locking the other?
(2) Do I need to rework my lower end? And ,if yes, how do I make sure I'm not a tooth out of alignment like what is discussed in the above referenced post?
