2006 Yamaha F150TXR, 4-stroke: Motor will only hit full RPM's for a short period of time, then fall back to about 4,000RPM's . The idle goes up and down between 500-700 RPM's and wont level off. To top it off, the primer bulb won't get hard.
Whats been done: New plugs, new VST filter, new water fuel separator unit, new line from the separator to the engine, new primer bulb......still really no change at all. All lines are tight, no leaks on anything.
Any advice on what might be going on?
