Re: Mercury 150 problems
The jumper wire is there. Will the engine be ok without the idle stabilizer? I hear a lot of different opinions.
As I think through it a bit more, the red/white connection between the stabilizer and the swtichbox is the high speed stator connection, and if that were shorted to ground, you'd get the bank it's connected to dropping at high speed. Makes sense now.
If the engine is in good tune, the idle stabilizer isn't needed. What it does is advance the timing a few degrees if idle speed drops below a set point.
Some engines had only an idle module on them. some had 2 modules on the, one idle and one advance module, and some had a combination module on them with both functions.
If the advance function is on the engine, WOT timing will be specified at 18?, and the module will move it another 6? at over 5000 rpm. If it doesn't have an advance function on the engine, WOT timing will be specified at 22? - 24?. So if you remove that function, you have to advance the WOT timing or it'll be pretty lazy at high speed.
Most of us just pitch all timing modules and set idle where it wants it, and WOT at 23?.
hope it helps
John
