Hey Gang. I'm new here and also new to boating. Last fall I purchased a 78 Silverline with a 120/400 stringer. Is there any chance that it may be normal to leak oil when the drive is tilted up? I had it apart last fall to put in a new impeller and felt that I did a pretty good job of getting it sealed back up. I normally have the drive in the down position, but went away for the weekend and left it tilted up. When I got home there was oil leaking but it is hard to tell from where. On the under side where the lower bolts on there are 2 small holes. It almost looks like that is where the oil is coming from. I'm hoping that this is just because I left it tilted up, but do you think I need to take it apart again?
