I have a 2001 Johnson 50 hp 2 stroke motor. It runs fine and all at once it begins to shudder and vibrate and will only turn around 2500-3000 rpms. If you turn off the ignition and start it right back up, it runs fine and may run like that for hours and then without warning it will start again, turn it off and back on and it is fine. New primer bulb and plugs installed. Thanks
