1996 Jonhson 115hp v4 10amp stator 35 amp regulator.
I'm on my 2nd voltage regulator on this thing. Had turned off the battery switch while it was running (yeah I know, don't do that) It of course fried the VR. Got another one and it did the same thing charging 16.5. Called CDI, they said to replace the battery. I cleaned all the connections and replaced with an Exide / Interstate XXHD 1000mca starting type battery.
Just got done splitting all the accessories over onto the Deep Cycle and putting in a Voltmeter on the starting/charging side. Start her up and the voltage slowly climbs to 16.66 volts nothing else drawing on that battery.
I'm really stuck at this point - even bypassed the a-b-both-off switch with cables direct to the battery - same results. Stainless washers lock washers and nuts used on the battery all the connections are clean and tight.
This all seems to have started when I did the bonehead move of switching off the power while running the engine. I would think if the stator was damaged it wouldn't be putting out voltage.
Could really use some help on this one.
BTW- the tach does not register while running switch on drops to zero and stays there. The tach has been replaced as the other was fried when the initial damage took place.
